mental high ping
mental high ping
1 <1 ms <1 ms <1 ms 192.168.0.1
2 25 ms 24 ms 25 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
3 25 ms 24 ms 23 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 24 ms 24 ms 25 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
5 25 ms 244 ms 216 ms lonap.thn-1.as25369.net [195.47.243.202]
6 25 ms 24 ms 25 ms 217.146.81.254
7 25 ms 25 ms 25 ms server109.55.4u-servers.co.uk [195.20.109.55]
I have already phoned with this prob but heres the tracert result neways hope it helps and u fix it soon. I play css cant shoot fook all with 250 ping Sad
mental high ping
Had same problem earlier tonight about 8.30 ish. Ping was up over 200ms and a tracert showed similar results to yours, unfortunatly have no results to display as all seems fine with my ping now.
mental high ping
Loads of members are having the same problems Sad
PlusNet hopefully are looking into it for us and will be fixed by tommorow.
LiamM
mental high ping
Is it just me, or is there nothing wrong with a ping of 25?
Yes... it's on the higher side of acceptable... but I wouldn't say theres a huge issue.
Also, given it's between you and PN on the first hop it's either something your side, or along your route to Plusnet. Perhaps a busy exchange?
mental high ping
martinfamily, try reading the below link
http://portal.plus.net/central/forums/viewtopic.php?t=35023
mental high ping
2 25 ms 25 ms 25 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
3 35 ms 25 ms 24 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 24 ms 24 ms 23 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
5 25 ms 24 ms 24 ms lonap.thn-1.as25369.net [195.47.243.202]
6 248 ms 231 ms 200 ms 217.146.81.254
7 25 ms 27 ms 25 ms server109.55.4u-servers.co.uk [195.20.109.55]
look again at 5 on the previous 1 m8 this is not accaeptable
LiamM
mental high ping
Aha, I didnt see that one.
On that note, given that is more lengthly, I am going to lock this thread to keep the discussio all in one place :
Does sound like an issue that needs investigating to me though.
