losing connection
losing connection
This happens quite randomly, usually once a day, i have to go onto my router settings and recronnect it, then it works fine, the routers not been reknoun for connection problems and got 5/5 on most/all reviews so i decided to buy it, but its a rather irritating problem. i carry on chatting on MSN Messenger with no problems at all.
I have also encountered this problem with various other modems so could it not be my end?
Hardware:
-Linksys WAG354G
-D-Link DI-634M
Layout:
Linksys router is connected to internet, plugs into D-Link routers WAN port, all set up right. Computers use D-Link router to connect to network 'cas of good wireless signal/strength.
please help Cheesy
losing connection
Does your rotuer give you line stats?
losing connection
says everythings okay dokay. same with previous modems
losing connection
Seemed to have fixed the problem due to DNS problem but get horrible lag spikes in game every 10-20secs even though my ping is constant 20ms.
Router setting is on: Keep Alive: Redial Period 20sec
Should i use something else?
ADSL Connection settings:
DSL Status: UP
DSL Modulation Mode: GDMT
DSL Path Mode: FAST
Downstream Rate: 1152 Kbps
Upstream Rate: 288 Kbps
Downstream Margin: 6 db
Upstream Margin: 28 db
Downstream Line Attenuation: 49
Upstream Line Attenuation: 29
Downstream Transmit Power: 0
Upstream Transmit Power: 0
PVC Connection
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
Qos: UBR
Pcr Rate: 0
Scr Rate: 0
Autodetect: Disable
VPI: 0
VCI: 38
Enable: Yes
PVC Status: Applied
losing connection
If thats what I think it is (The Signal-To-Noise Ration) then it looks awfully low...
losing connection
any ideas on what i can do?
losing connection
Phone BT and ask then to up the gain on your line (amplify the signal more) . They will do it if you persist unless you are quite a distance from your exchange. I have a SNR of 36.5 dB and am about 1/2 mile from the exchange so judge whether your SNR is OK or not for your own location.
losing connection
ive tried it before and they said you cant do it for ADSL lines o.O
were they lieing?
