login
jabb0
login
is it just or does the login on this page linky never ever work?
oh u will have to coy the link and then logout to try it methinks - but thats prolly obvious, didnt mean to insult ur intelligence.
Plusnet Staff
Plusnet Staff
login
Works fine for me, which browser are you using?
jabb0
login
Firefox on linux
Not too big a problem mate as the next screen gives me a different login which always works.
I am not jus doin this on a whim its been like this for bout a week possible more, in fact probably more, and today i decided to type my details at 1 key per 2 seconds taking extra care to hit the right keys Cheesy
as i said no biggy - jus thought u might like to its broke :O
either that or i am alot thicker than i think Wink
Fixes: 8
login
I've just tried this using latest Firefox on Mandriva - logged in no problem.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Discostoo
login
I'm using firefox on XP (1 out of 2 aint bad) and it doesn't work for me, but the second page does, but then logs me into a random page in one of the forums. weird.
Plusnet Staff
Plusnet Staff
login
Ah, are you using either a bookmarked page or reloading the browser from where you left it?
I've seen similar in Opera occassionally with LloydsTSB where you open the browser with all the tabs you had before but it loads the page from the cache and typing the username and password in doesn't work because the previous session has timed out.
Discostoo
login
Cheers for that, that's exactly the reason. Because i hadn't logged out either it was taking me to the page i was at before i killed the browser. (killed is a bit harsh, but i'm showing my roots there) Tongue
jabb0
login
yes i do the same - thanx for that - im not crazy after all Cheesy
Discostoo
login
weirdest thing - just about to login, and i pushed the down key to bring up my stored name, and instead of "discostoo", up popped "morvan123".
What's this all about? Is there someone here with that username? I'm the only one using my PC, and i've never seen that before. random.
shellsong
login
Yes there is a morvan123, according to the search facility they've only posted 7 times and off the main forum at that
