little question
little question
It was said that I would have to leave my connection going for 10 days in order for an accurate reading to be made on what speed my line can handle. Does this mean I have to leave my router on 24/7 for 10 days without a rebootor being turned off?
It shouldn't matter. BT will require 3 separate connections to calculate the Maximum Sync Rate, so ideally, it would be best for you to reboot the router every 2-3 of the first ten days. We're currently looking into measure to prevent this from being required.
Just wanted to know what 1 days do i have to reboot my routers for BT to get good test results. Is it after my billing date?
1 REPLY
James
little question
It's once you have been upgraded to the higher speeds. You'll be notified in due course.
