linux router/firewall problems since MaxDSL
Not quite sure if this is the right area to post this but.... My dedicated linux router box (IPcop software) has been having trouble reconnecting (probably re-synching) when the line drops. I use the revision 4 speedtouch USB modem, but the same happens on my Fujitsu FDX310 modem. I think the problem lies in the box insisting on reconnecting at the same speed each time while MaxDsl is RADSL i.e. different synch speeds. Anybody got any suggestions/similar experiences ? At the moment I am connected using a dedicated Windows box and a Zyxel Prestige 630-11 USB modem, hardly secure but at least functional.
David
1 REPLY
The obvious simple answer is to use an ADSL router, but I presume that you have a reason for using a dedicated PC and a modem.
Eric
