level 1 management too severe on usenet
Hi All,
I'm on "Level 1 Management" on Option 1, this month... ooops.
During peak times usenet (giganews) runs at <1kb/s, shouldn't it be limited to 256kbit (i.e. 32kb/s)Huh?
During off-peak times the speed seems to fluctuate with a minimum of 200kb/s and peaking at 600kb/s (avg c. 450kb/s) which is quite good really.
Any idea why the restrictions are so severe during peak time?
Hugs and kisses
Tom
1 REPLY
Plusnet Staff
Plusnet Staff
The speed is set to a maximum of 256knps on usenet on level 1 management at peak. However as the traffic is restricted it's put in the bronze queue which is the first traffic to get dropped when the network is busy, i.e. at peak times. With the speeds on Usenet and P2P slower than normal (see http://usertools.plus.net/status/archive/1158168848.htm for details) the speeds on leve1 management will be even lower.
I'd recommend scheduling usage off peak as it should run fine then.
