is plus net blocking my website?
truvoice
Can you please help me out and tell me if you can access http://bigbwoyz.co.uk because I haven't been able to for 2 days.
However, when I use this proxy browser (http://www.free-proxy.info/) I can see my website.
If any of you have time can you please check this out.
Also, if it is blocked is there anything I can do? My webhost is webdockers, I cannot access their website either.
I can access your site and http://www.webdockers.com/uk/
snap! I too can access both.
A
Seems ok here m8.
Yep site is available to me too Smiley
Same here. No problem Smiley
truvoice
Can someone please help me then. I have tried to access it on both my laptop and desktop. They both connect to the internet via a wireless router. Do you know what the problem could be?
Craigiusmaximus
just got this message.
bigbwoyz.co.uk is currently unavailable as we are carrying out an update for the whole website.
Please check back later.
We apologise for any inconvenience caused by this.
truvoice
then you can access it, the server times out whenever i try. I dont get it.
Craigiusmaximus
Yeah i can
this is odd?
Have you tried restarting your router?
ie turn it off for a minute or so and reconnect?
have u messed with any RWIN or TTL settings on your PC or router? I did that and found i coudldn't access HSBC. Changed it back and it works fine
truvoice
I cant access it by ftp either.
Can you get there with a web proxy?
truvoice
yea, i can get there with a web proxy.
Also I just did restored the factory settings on my router and i still cant access it.
