internet connection
internet connection
has anybody had trouble with going offline then having to connect agian,its happened twice in the last 2 days now,,is it because im a new customer and its settling itself down?Huh
Fixes: 8
internet connection
Are you using a modem or a router? Some equipment does have an idle timeout to disconnect - you should check for that first.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Plusnet Staff
Plusnet Staff
internet connection
It could on the other hand be just because it's new. With DSLMax it is normal for a few disconnections in the first 10 days or so. Take a look at this for more information.
http://portal.plus.net/support/broadband/products/getready.shtml?link=suptop5_general5
