interleaving....
interleaving....
Should I leave it turned on or turn it off, as I have noticed there is now an option under Connection Setting's to turn it off, but once turned off you cannot turn it back on? should I leave it on?
interleaving....
wothout interleaving you may get a slower connection in temrs on bandwidth but latency/lag will reduce. If you are not a gamer or use VPN I'd leave it alone.
interleaving....
I will leave it alone then, thankyou!
oakuka
interleaving....
I dont have this, im a gamer and im experiencing really bad lag lately, can some one check if i have it on or off plz and switch it to the one thats better for gaming?
interleaving....
turning off interleaving may also make a connection more unreliable if the line is particularly noisy.
interleaving....
You can check in your router/modem stats and look for 'Latency Mode' or similar. 'Fast' is not interleaved, 'Interleaved' is, well, interleaved.
I believe there is now a button in the portal conection settings to switch it off, never needed it so don't know exactly where it is.
oakuka
interleaving....
Speedtouch 330
ChannelMode= Interleaved
Does that explane why im getting whoring lag!?
interleaving....
you can also check to see wether you have interleaving switched on or off by clicking on the appropriate link on the page below...
https://portal.plus.net/my.html?action=myconnection&?membermenu=connectionsettings
interleaving....
It would explain high pings, and maybe a bit of lag, but I think Plusnet's over-subscription on it's network explains most lag. My pings are nearly the same as they have always been +5ms, but playing the same game on the same server now lags a lot more than it did a year or two ago.
oakuka
interleaving....
Well i play CSS alot, and from a low 20-30 ping on a uk server i get 50 - 500 with horrible spikes of lag.
interleaving....
Interleaving increases your ping by around 20ms, it doesn't explain pings of up to 500ms though. I have been seeing pings of up to 900ms in game to a US server which usually pings around 120ms. Personally, I am migrating soon as I do not think the Plusnet network can cope with the volume of traffic.
oakuka
interleaving....
Yeah i'm wanting to migrate, but ££ is not an option.
So my best chance is to turn off interleaveing off then!
interleaving....
Turning it off will give you a better ping but decrease your synch/download speed slightly, I have it disabled as I am a regular gamer, and high synch doesn't mean much when you can never max the connection any way due to throttling.
oakuka
interleaving....
Yeah im a gamer too, leauges soon, so i need a good ping.
Suppose its CSC ticket next. Chears for the info and help.
interleaving....
You should see a button in your 'Connection Settings' in the portal to turn it off, no need to raise a ticket any more.
