inactive message
inactive message
hi, earlier while i was using plusnet, a box came up saying plusnet has been idle/inactive for 20 mins then it said something about auto connect? (cant remember). without thinking, i clicked stay connected instead of ticking the box saying dont use auto connect. how do i turn it off without waiting for that box to re-appear?
inactive message
IE/Tools/Internet Options/Connections/Settings/Advanced/Disconnect when...
Try that
inactive message
done now. thanks for that Smiley
