how do these stats look ?
I know i live a relative distance away from my box so will have difficulty getting anything above 2mb , my line at the mo is 1mb. but i have and do regularly download at my max , solid for long periods.
I have taken some stats from my router and was wondering if any tech minded people out there could inform me if the outlook is good , bad or average in relation to getting some kind of speed increase in the future.
Down Up
SNR Margin 7.9 19.0 dB
Line Attenuation 60.5 31.5 dB
Thanks In Advance
Smiley
You won't get more than your currntly get if you upgraded to Max or get switched to LLU. The SNR is the problem figure and that is already low, even under the old line stats.
You really are a long way from the exchange so Max/LLU is not going to get you any faster speeds I'm afraid. If you are really unlucky you may actually not get 1Mbs.
thanks for the promp answer , much appreciated !!!
yeah i know its the distance from the exchange thats the prob. But I guess im content with what i have , just wondered what the numbers meant ect.
You make a comment about i might actually not get 1mb , what do you mean by that ?
do i need to opt out of something or contact plus to tell them to not mess with my line for fear of a poorer speed ?
I would say go to trials.plus.net and hit the buton to opt out from MaxDSL, you are very likely to get less than 1Mb on that line.
SW.
3Mb FTTC
Sorry to jump in, but what do these figures look like?
ADSL Link Downstream Upstream
Connection Speed 1152 kbps 288 kbps
Line Attenuation 59 db 15.5 db
Noise Margin 13 db 21 db
Thanks in advance Dave
They are similar to mine. On max I initally got around 2500Kbs down, 432Kbs up but after a while this reduced to 1200Kbs down, 432Kbs up (no idea why it reduced but I could never get it to go any higher - I raise a ticket but after 3 weeks I was moved to LLU so never got to the bottom of it).
So you may get a large increase initially but in the long run you will probably stay the same or get a slight increase.
On LLU I am currently getting 1530Kbs down, 576Kbs up.
The high attenuation means you are going to be affected by noise if there is any, but your current noise margin should see you coping with that.
My line stats were similar to yours on 1Mb, I now get 2.5Mb but get a disconnect most nights, that causes 30s loss of service.
SW.
3Mb FTTC
Thanks guys.
Well I will see on the 6th July as I have just migrated to BT and my Max "should " be up and running by then. :!:
update
Bt engineer visited today ,
did as much as he could with the line ,
told me that the SNR was the culprit for the dropping connection , said that anything under 10 would possibly cause dropouts and i was hovering at 7-8 .
An hour later and some fantastic work from the guy I have a solid SNR of 15 and no line drops , my distance from the exchange obv will not change but i should now have a stable line with no dropouts ,
Thanks plusnet and bt for your help getting this sorted !!
Had,Max activated last thurs.
See results
System Up Time 58:31:12
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 78832 87349 0 123 752 28:33:17
LAN 10M/100M 274017 388409 0 1062 234 58:31:08
WLAN 11M/54M 170482 0 0 53 0 58:30:58
Connection Speed 1760 kbps 448 kbps
Line Attenuation 61 db 15.5 db
Noise Margin 6 db 14 db
speedtest gives me this
Dan Elwell's Broadband Speed Test
Speed Test Report 0607101435.std
Test conducted at: 10/07/2006 14:35:00
Test sequence: Full test
Please note that these results are a snapshot of this particular moment. Run the test a few times to ensure maximum accuracy. Although the test has been constructed to be highly accurate, no guarantees can be made to the level of accuracy experienced in everyday use.
Test 1: Ping times to UK servers
Ideally, you should get a result of around 30 ms (lower is better)
linx.net: 23 ms
plig.net: 23 ms
southwark.gov.uk: 35 ms
vantage.myby.co.uk: 30 ms
The results of this test indicate no problems.
Test 2: Ping times to European servers
Ideally, you should get a result of around 50 ms (lower is better)
sunet.se: 56 ms
sunsite.cnlab-switch.ch: 51 ms
free.fr: 34 ms
free.fr: 34 ms
Test 3: Ping times to east-coast USA servers
Ideally, you should get a result of around 120 ms (lower is better)
ftp-linux.cc.gatech.edu: This test failed due to a server timeout or other error.
dulug.duke.edu: 110 ms
upenn.edu: 21 ms
aeneas.mit.edu: 97 ms
Test 4: Ping times to west-coast USA servers
Ideally, you should get a result of around 160 ms (lower is better)
redhat.netnitco.net: 148 ms
limestone.uoregon.edu: 167 ms
ucla.edu: 170 ms
ucla.edu: 169 ms
Test 5: Ping times to east Asia servers
Ideally, you should get a result of around 300 ms (lower is better)
apache.oss.eznetsols.org: 386 ms
apache.oss.eznetsols.org: 361 ms
meisei-u.ac.jp: 282 ms
apache.oss.eznetsols.org: 373 ms
Test 6: Ping times to Australian servers
Ideally, you should get a result of around 350 ms (lower is better)
apache.inspire.net.nz: 604 ms
planetmirror.com: 341 ms
bondinet.com: 403 ms
apache.inspire.net.nz: This test failed due to a server timeout or other error.
Test 7: Ping times to central Asian servers
apache.dnepr.net: 87 ms
apache.rinet.ru: 92 ms
apache.fresh.co.il: 108 ms
apache.rin.ru: 78 ms
Test 8: Download speeds from UK servers
Ideally, you should get a result of around 1728 Kb/s (higher is better)
apache.rmplc.co.uk: This test failed due to a server timeout or other error.
Too many server errors occurred therefore this test is inconclusive.
Test 9: Download speeds from European servers
cvut.cz: 249 Kb/s
This result shows serious problems with your downloads, and should be investigated.
Test 10: Download speeds from east-coast USA servers
csh.lkams.kernel.org: 93 Kb/s
Test 11: Upload speeds to the Speed Test Server
Ideally, you should get a result of around 448 Kb/s (higher is better)
broadbandspeedtest.net: 137 Kb/s
This result shows serious problems with your uploads, and should be investigated.
Test 12: Packet loss en route to a UK server
Ideally, you should get a result of around 0 % (lower is better)
cardiff.ac.uk: 2 %
f2s.com: 0 %
A small amount of packet loss has been detected. This should be investigated.
Test 13: Packet loss en route to a European server
uni-kl.de: 2 %
rediris.es: 0 %
Test 14: Packet loss en route to an east-coast USA server
club.cc.cmu.edu: 2 %
ibiblio.org: 4 %
End of testing.
This report was collated using Dan Elwell's Broadband Speed Test. For more information or to download, please visit www.broadbandspeedtest.net.
Generated 10/07/2006 23:10:18 using test version 3.0.316 - registered copy
