homesurf
vic_newey
homesurf
Why does Winmtr stats show me as being on homesurf ? thought that was extinct now as I am on premier
LiamM
homesurf
Are you definately on Premier?
If so, have you enabled the 'Surf' option from within the Portal?
vic_newey
homesurf
I am on 1 meg premier, surf is not enabled in my connection settings either ,
am I getting some kind of throttle ,seems like it lately
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| lo0-homesurf.ptn-ag2.plus.net - 0 | 9 | 9 | 16 | 23 | 32 | 16 |
| ge1-0-0-206.ptn-gw2.plus.net - 0 | 8 | 8 | 16 | 31 | 47 | 32 |
| gi4-0-23.pth-gw2.plus.net - 0 | 8 | 8 | 15 | 23 | 32 | 32 |
| atm0-1-0.ptb-gw1.plus.net - 0 | 8 | 8 | 31 | 31 | 32 | 32 |
| vlan18.pri.ptb-gw4.plus.net - 0 | 8 | 8 | 31 | 31 | 32 | 32 |
| if2.ptb-al1.plus.net - 0 | 8 | 8 | 31 | 31 | 32 | 32 |
| portal.plus.net - 0 | 8 | 8 | 31 | 31 | 32 | 32 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
homesurf
First off, where you originaly on Homesurf to start out with?
Secondly and if yes to the above, did you ask to be moved to premier, or are you operating under the assumption that this move took place automaticaly?
If you did not ask to be moved and your price is the same at £18.99 a month, then things are perfectly normal.
You are indeed correct that the account is no longer available however, this is only for new sale. Customers that remained on Homesurf post changes, will continue to do so today.
The Homesurf product is still very attractive to many, in that blocks are only in place on P2P and Usenet only, in favour of the priority levels hat can exist on the cheaper products.
Moving to Premier would involve the price increase to £21.99 a month and can be done without any admin charges (unless you request a speed upgrade, which is charged at £15).
Plusnet Staff
Plusnet Staff
homesurf
Have you ever enabled the Surf option? And if so have you disconnect/reconnected since turning it off?
vic_newey
homesurf
I pay £21.99 a month ,originally would have been on homesurf when I first joined +net .I don't have'surf enabled on the portal either
