hi all
hi all
i keep hearing about avatars , ok what is it ,where is i,t if you have one why cant i see it ,and if i have 1 whats it look like thank you
hi all
an avatar is a little image under your username on the forums.
for example my avatar is:
As for why you can't see them I don't know....[/img]
JonathanW
hi all
At the bottom of this page you can link to an avatar that is stored somewhere else on the web. Most people store these on their PN provided webspace. Though I would suggest checking out the forum rules as there are some guidelines on avatars.
ta
thanks all but i cant even see anyones avatar [think my pc is blocking it [does it use java or is it html [which is off on my diary thingy where you apply the piccie]
hi all
No, its just a simple image in the page. If you are viewing secure (SSL) pages (check the url in the address bar to see if its http:// or https:// if you are viewing via https it sometimes causes an issue as the images are still using a non secure link (its not a security problem though).
What broswer are you using?
f
firefox
hi all
I dont use firefox, so dont know the setting on it. But can you confirm if you can see the image no7oliver added to his post above? And can you see the PlusNet banner adds and logo at the top of the page?
Fixes: 57
hi all
I suspect you need to change the firefox settings. If you go into Tools/Options/Content (the globe symbol) and deselect Load Images for the originating web site only this may solve the problem. Don't forget to refresh the page afterwards
hi all
holtlane spot on that worked
