has anyone elses speed dropped by half
winnipeg1823
For months I have been connecting at 1.1mbs. I am now down to 622kbps. I have not downloaded more than 0.5mgs this month so far. Has anyone else had this happen to them, and if so what is the problem
Fixes: 8
Is that the connection speed or the result you are getting on a speed test?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
winnipeg1823
Its the connection speed
Fixes: 8
That's not a situation I've heard of before - suggest you raise a ticket to ask what's happened.
