grr time stamp in forums
Is there anywhay to change the forum so times are displayed in 24 hour fomat.
rather than the silly 05:30pm it should be 17:30
niggle niggle niggle..
Fixes: 5
Yep, easy enough. Click on Profile at the top of the forums page, then change the time format to 'd M Y H:i' with out the quotes.
Phil
Thanx ,that has been annoying me as well
While we are on the subject why cant i see my selected Avator It is within the size recommended , correct path but just get a red cross
Hi
Your avatar appears to be stored on your hard drive. Have you tried uploading it your webspace and then linking to from there.
Hope this helps.
woot
Cheers
thats sorted it.
LiamM
Did it? I can't see nowt. :shock:
Mistaken id
avatar is still giving me jip hence no image
LiamM
Oops.....
Fixes: 5
Liam
It's astyler's time problem that's sorted, not iynishad's avatar.
Phil
Pathfinder
Confused? You will be. :?
As you can still see "nowt" yes i am having problem
image is in my webspace but wont except link when pasted to my profile
nothing any ideas ?
Pathfinder
OK, give us the URL to the image first and then we can go from there.
Fixes: 5
Can you post the url of the image on your webspace?
Phil
ftp://www.ishad.co.uk/htdocs/borg3.bmp
Pathfinder
OK, that is FTP and not HTTP, also it is password protected. That is why you can't see it.
You may get away with:
ftp://username:password@www.ishad.co.uk/htdocs/borg3.bmp
but that isnt very clever as you would expose your name and password for that FTP server in the source of the forum page. :shock:
