fresh new network
Slick
fresh new network
i have recently installed a fresh new wireless network so the kids can use the net but can anyone recomend a program so i can automaticly log on to there pc and view what they are viewing or if they need help etc?
Plusnet Staff
Plusnet Staff
fresh new network
If you're using Windows XP Pro then you can use the built in Remote Desktop or Remote Assistance features. If not then VNC is what you are looking for, Tight VNC and Real VNC are both free and let you control the other PC or just view what it's being used for.
___oDiN__
fresh new network
radmin works very well and you can install it silently on their pcs and monitor without them knowing, handy if you want to check they are using the net safely or suspect some dodgy web browsing !
fresh new network
I'd recommend using RealVNC or TightVNC, they are very good, allows you to see your kids computers without them knowing (The wee vnc icon in the tray does invert its colours when you connect however I think this can be disabled) and you can also take control of it! You can also view their computers from anywhere with an internet connection even if you dont have the program as you can use your web browser!
fresh new network
But make sure all these programs require a password for access, AND that they are blocked (either by options or by your firewall) from acting as a server to the internet - or you risk the PC being remotely controlled or viewed by a hacker.
LiamM
fresh new network
I second this. I've used radmin at a number of locations, and it works very well indeed. Radmin = Remote Administrator. Search for it on download.com.
