frequent disconnections
Recently I have started getting frequent disconnections of my broadband connection. Im including the trace from my router. Any ideas what can be causing it? I tried replacing the router with another and got the same results.
Thanks.
(NOTE: Ive XXX'ed out my IP address)
Jul 3 23:36:40> get 0xF at Addr 0xA30085B0
Jul 3 23:37:04> DSL out of sync
Jul 3 23:37:11> DSL Carrier is down
Jul 3 23:37:26> DSL in Sync
Jul 3 23:37:31> DSL Carrier is up
Jul 3 23:37:31> sar read trained mode (1)(ADSL_G.dmt)
Jul 3 23:37:32> PPPD Terminated Through Signal
Jul 3 23:37:33> Connection terminated.
Jul 3 23:37:33> pingStat 2, oamHdr 230 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 200 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 280 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 240 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 260 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 600 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 800230 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 2B0 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 330 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 3B0 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 8002B0 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 800330 result 0
Jul 3 23:37:33> pingStat 2, oamHdr 8003B0 result 0
Jul 3 23:37:33> get 0xF at Addr 0xA30085B0
Jul 3 23:37:33> ppp0
Jul 3 23:37:33> closing 0.0.38.5
Jul 3 23:37:33> tn7sar_teardown_complete called for channel 0
Jul 3 23:37:33> ChannelTeardown returned rc = 0
Jul 3 23:37:33> pppd 2.4.1 started by root, uid 0
Jul 3 23:37:33> Connect: ppp0 {--}
Jul 3 23:37:36> ppp0
Jul 3 23:37:36> WAN IP address XXX.XXX.XXX.XXX
Jul 3 23:37:36> PPPoA Connect with IP Address XXX.XXX.XXX.XXX
Jul 3 23:37:36> PPPoA Connection Successfully Established
Jul 3 23:37:36> PPPoA Connect with Gateway IP Address: 195.166.128.123
Jul 3 23:37:36> WAN gateway 195.166.128.123
Jul 3 23:37:36> primary DNS address 212.159.6.9
Jul 3 23:37:36> secondary DNS address 212.159.6.10
Jul 3 23:37:37> get 0xF at Addr 0xA30085B0
Jul 3 23:37:49> get 0xF at Addr 0xA30085B0
Jul 3 23:37:53> get 0xF at Addr 0xA30085B0
Jul 3 23:37:54> get 0xF at Addr 0xA30085B0
Jul 3 23:38:06> get 0xF at Addr 0xA30085B0
Jul 3 23:42:00> get 0xF at Addr 0xA30085B0
Jul 3 23:47:38> DSL out of sync
Jul 3 23:47:51> DSL Carrier is down
Jul 3 23:48:01> DSL in Sync
Jul 3 23:48:01> DSL Carrier is up
Jul 3 23:48:01> sar read trained mode (1)(ADSL_G.dmt)
Jul 3 23:48:02> pingStat 2, oamHdr 230 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 200 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 280 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 240 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 260 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 600 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 800230 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 2B0 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 330 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 3B0 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 8002B0 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 800330 result 0
Jul 3 23:48:02> pingStat 2, oamHdr 8003B0 result 0
Jul 3 23:48:02> get 0xF at Addr 0xA30085B0
Jul 3 23:48:02> ppp0
Jul 3 23:48:07> PPPD Terminated Through Signal
Jul 3 23:48:07> Connection terminated.
Jul 3 23:48:07> closing 0.0.38.5
Jul 3 23:48:07> tn7sar_teardown_complete called for channel 0
Jul 3 23:48:07> ChannelTeardown returned rc = 0
Jul 3 23:48:07> pppd 2.4.1 started by root, uid 0
Jul 3 23:48:07> Connect: ppp0 {--}
Jul 3 23:48:09> WAN IP address XXX.XXX.XXX.XXX
Jul 3 23:48:09> ppp0
Jul 3 23:48:09> PPPoA Connect with IP Address XXX.XXX.XXX.XXX
Jul 3 23:48:09> PPPoA Connection Successfully Established
Jul 3 23:48:09> PPPoA Connect with Gateway IP Address: 195.166.128.64
Jul 3 23:48:09> WAN gateway 195.166.128.64
Jul 3 23:48:09> primary DNS address 212.159.6.10
Jul 3 23:48:09> secondary DNS address 212.159.6.9
Jul 3 23:49:11> get 0xF at Addr 0xA30085B0
Jul 3 23:49:15> get 0xF at Addr 0xA30085B0
Never mind - looks like the router was set to adsl2 - changing it back to normal adsl seems to have stopped the disconnects.
Mand
Glad to hear you got it sorted. Smiley
Hmmm - well looks like it is still there - just less frequent. Currently the modem is configured to use ADSL_G.dmt
Any ideas?
Jul 23 03:40:18> PPPoA Connection Successfully Established
Jul 23 03:40:18> PPPoA Connect with Gateway IP Address: 195.166.128.80
Jul 23 03:40:18> WAN gateway 195.166.128.80
Jul 23 03:40:18> primary DNS address 212.159.6.10
Jul 23 03:40:18> secondary DNS address 212.159.6.9
Jul 23 09:35:41> DSL out of sync
Jul 23 09:35:52> DSL Carrier is down
Jul 23 09:36:05> DSL in Sync
Jul 23 09:36:12> DSL Carrier is up
Jul 23 09:36:12> sar read trained mode (1)(ADSL_G.dmt)
Jul 23 09:36:13> PPPD Terminated Through Signal
Jul 23 09:36:13> Connection terminated.
Jul 23 09:36:13> pppd 2.4.1 started by root, uid 0
Jul 23 09:36:13> Connect: ppp0 {--}
Jul 23 09:36:13> pingStat 2, oamHdr 230 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 200 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 280 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 240 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 260 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 600 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 800230 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 2B0 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 330 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 3B0 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 8002B0 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 800330 result 0
Jul 23 09:36:13> pingStat 2, oamHdr 8003B0 result 0
Jul 23 09:36:13> get 0xF at Addr 0xA30085B0
Jul 23 09:36:13> ppp0
Jul 23 09:36:13> closing 0.0.38.5
Jul 23 09:36:13> tn7sar_teardown_complete called for channel 0
Jul 23 09:36:13> ChannelTeardown returned rc = 0
Jul 23 09:36:17> PPPoA Connect with IP Address xx.xx.xx.xx
Jul 23 09:36:17> PPPoA Connection Successfully Established
Jul 23 09:36:17> PPPoA Connect with Gateway IP Address: 195.166.128.123
Jul 23 09:36:17> WAN IP address xx.xx.xx.xx
Jul 23 09:36:17> WAN gateway 195.166.128.123
Jul 23 09:36:17> primary DNS address 212.159.6.10
Jul 23 09:36:17> secondary DNS address 212.159.6.9
Jul 23 09:36:17> ppp0
Plusnet Staff
Plusnet Staff
Do you know if it's always losing sync when the connection drops or if it just drops PPP? If it is losing sync then this is worth a read:
http://usertools.plus.net/tutorials/id/13
