for the UN-NERDY amongst us. Please
I have browsed through a lot of postings and many people seem to have knowledge that I don`t have. I can`t be the only one who needs things explained very simply
eg:
what is a catch all and why should it be off at the moment?
why have an alias? eg I switched catch all off yesterday and an alias called `postmaster` was set up. This was the only one I had. What did it do?
I was sent an e mail today and it has not arrived. Is the catch all stopping it?
and so on please
waldron
If your username is 'blahblah' then your default mailbox is blahblah@blahblah.plus.com.
If this is your only mailbox -
If someone sends you a mail to fred@blahblah.plus.com
Then if catchall is ON the default will pick it up.
If catchall is OFF, it will be rejected.
If you want to receive emails to 'fred' then you need to either set up an additional mailbox, or make 'fred' an alias of the default one.
Hope that helps.
wonderful. Thank you very much. I have made the alias and had an e mail sent to me. It worked
Fixes: 132
What are the benefits of an alias over a dedicated mailb0ox or visa-versa?
Forum Moderator and Customer
waldron
If you have a dedicated mailbox you access it individually. With an alias you can gather a number of addresses into one single access.
Fixes: 132
That's what I thought, but it just seemed to simple an answer Shockedops:
