flex modem problem?????
owlguard
Hello,im looking for new pc and have seen a few what have said they have a flex modem and to check that this works with your isp,can anyone give me a definete answer on this little problem.
regards ray.
Unless i'm much mistaken Isn't that a dial up modem? If so it won't work on ADSL...
owlguard
Thanks for that mate,i have a spedtouch330 usb modem that im using now for my broadband but im a thick 57 year old Yorkshireman.Does it mean i dont really need a modem in my pc,I know my present pc has a modem but i am not savvy to these things as you can see.I dont intend going back to dialup but would having a pc without a dialup modem in it leave me disadvantaged.
regards ray
Alecto
Depends on whether you want the option of dialup backup if your broadband goes down.
I've not got a dialup modem, as you can do sod all with dialup apart from the odd email and logging on to the forum, and most people I know don't bother with one either. If BB goes down, I just wait for it to come back up.. A rare occurrence anyway.
And it might save a pound or two not having one. But it's personal choice really.
Dial-up Modem
For the small cost of a modem card I think it a good investment to have a dial-up backup connection.
Also, if you want to send / receive faxes on a 1ft or second line then it's also a good idea.
A pretty fair summation from Geoff.
I don't have one for my PC, but I do have one built into my laptop.
Would I pay any extra to have one? No. But it does depend on whether you are concerned at the possibility of being without net access if you have a problem.
My PC is upstairs and away from a phone socket, I use wireless to connect to my router which is downstairs. A modem would be pretty useless for me in my PC, since I have nothing to plug it into.
If you get one without a modem, and decide you need one later on, you can buy an external one if you don't fancy the idea of opening up the case. Last time I got one (a few years ago I admit) it was around £15. (An internal one would probably be a few quid cheaper)
No doubt somebody will add more up-to-date pricing for comparision. Wink
owlguard
Thanks to all who have given me advice about backup modems etc,thanks a lot.
@ James
I think atbs1 made a better summation actually. Wink
You're probably right! In my defence his post wasn't there when I started typing. Shockedops:
Yep, I have the same as James. No modem in my desktop, but I do in my laptop. I've been lucky not to have had hardly any broadband problems, except once when the connection went down at 1am. Though it was probably a good thing as it made me go to bed and was back on in morning Smiley
I only use the dial-up once per couple of months to keep my old BT Internet e-mail address active.
But as has been said, depends on how much not having a connection would affect you. I have net access at work, so for me it would be a pain, but not essential.
Alecto
@ James
Not true. He gave no reasons, simply his preference to have a modem. I, and many others, disagree with that.
I don't remember specifically saying you were wrong Geoff.
I said that,I think(as in my opinion) that atbs1 post, which does infact give a reason (a good one) to have a dial up modem, makes more sense than trying to save a couple of quid at point of sale on a new PC!
Not true.
:? Whatever!
