first hop higher
vic_newey
first hop higher
anyone know why the first hop is consistantly higher than the rest ? why 157
my pings were 15 prior to interleaving
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| lo0-plusnet.pte-ag2.plus.net - 0 | 6 | 6 | 125 | 138 | 157 | 157 |
| ge0-0-0-504.pte-gw2.plus.net - 0 | 6 | 6 | 31 | 31 | 32 | 32 |
| ge0-0-0-22.ptn-gw1.plus.net - 0 | 6 | 6 | 31 | 34 | 46 | 32 |
| 195.166.129.3 - 0 | 6 | 6 | 31 | 31 | 32 | 32 |
| se3-0.pih-gw1.plus.net - 0 | 6 | 6 | 47 | 47 | 47 | 47 |
| vlan8.pih-gw4.plus.net - 0 | 6 | 6 | 47 | 47 | 47 | 47 |
| pih-al4.plus.net - 0 | 6 | 6 | 47 | 47 | 47 | 47 |
| portal.plus.net - 0 | 6 | 6 | 47 | 47 | 47 | 47 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
first hop higher
Seems to be the norm at peak times now. Plusnet's lack of capacity.
Starting trace - May 16, 2006 20:31:20
Tracing to www.bbc.co.uk [212.58.224.89]....
Hops IP Address RTT(ms)
1 192.168.0.1 0
2 195.166.128.53 194
3 84.92.3.106 56
4 212.159.4.6 55
5 212.58.239.25 58
6 212.58.238.149 57
7 212.58.224.89 56
Dizzley
first hop higher
I raised a ticket on another day asking if it was exchange contention or were particular pipes busy. No-one hazarded a guess Sad. They wanted plenty of traceroutes etc. I would have thought they needed other user's traceroutes not mine to look for contention.
Those pings are crippling for gamers. No good at all sometime I've had 200ms first hop.
I don't think it's the exchanges as you can normally improve things by reconnecting to another pipe.
I want to know if this can be improved by PN buying more pipes. If so, when and if? Was it such a surprise when MaxDSL arrived? What's the news at other ISPs?
Fixes: 8
Re: first hop higher
Can I suggest if you are going to post tables you put them in code tags like this:
| WinMTR statistics |
It makes them a lot easier to read!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
vic_newey
first hop higher
I just copied to clipboard & pasted on here , code tags ?
EDIT: I just discovered what you mean, will use next time
Plusnet Staff
Plusnet Staff
first hop higher
We believe the problem is being caused by an issue on the ERX's, we've scheduled some maintenance work for Thursday morning which we think should fix this. It shoudln't make any difference with gaming because the ping time is only how long the ERX's take to respond rather than the traffic that goes through them (priority will always go to passing traffic through the routers than replying to pings).
