emule low id
emule low id
Firewall and NAT configured properly. Emule's online TCP port test fails.
Is this PN interference? Hardly ever use emule, but I need it for the occasional file.
On Prem, it used to connect just fine on Plus with high id.
emule low id
The low id is caused by the port not allowing incoming connections. It's not PN blocking it, so it's got to be your setup I'm afraid.
emule low id
I remember reading that emule was no longer "supported" by PN... I wonder if this has something to do with it....
emule low id
emule has never been supported by PN to my knowledge, but I know it works as I use it.
emule low id
broughcut, were you able to fix the problem yourself? I've recently got the very same problem.
Alecto
emule low id
@sch0lem
It is not a plusnet problem.
It means your ports are not forwarded correctly - or perhaps you are using the default ports and the site you are accessing blocks them.
Make sure you use a port that is far removed from the default, and check one of the tutorials on port forwarding.
emule low id
It was a problem with NAT. Have to admit I'd entered the wrong port number. Shockedops:
Alecto
emule low id
:lol:
emule low id
Thanks for the responses, I'll look into it Smiley This has only been a problem since my local BT exchange had a spanner in the works a few weeks back.
