email authentication problem?
Hello,
Just a general question here before I post a fault ticket with Customer Service, as if there's a general problem across many users I'll just sit tight for a while! Cheesy
Are any other users experiencing password authentication problems when checking email via their normal email client (not webmail)?
I seem to be able to connect once without a problem,,,then on my next attempt I get an error back informing me of a password/login failure.
I've checked the service status and I can't spot anything that may relate to my problem.....
Is it just me? :lol:
Cheers,
Tim
Just tried my email client and its downloaded the usual spam from all mailboxes. So it seems to be working fine here.
lingbob
Re: email authentication problem?
Yep, can't authenticate with Thunderbird and I can't authenticate with WebMail either. This has been going on with me for around the last 2 months. PlusNet have somehow managed to lock me out of my mailbox and despite escalating this twice to Networks, they haven't managed to fix it yet - Hello? - can somebody please find the key to my mailbox and unlock it! :roll:
gasguzzler
I have the same problem with Thunderbird yet Outlook works!? WTF?? :? :?
unable to log on to send e-mail
repeatedly asked for email account password.
using imap and relay.plus.net, well trying to anyway.
A
channel
Is this a recognised problem/is anything being done about it?
I have the same problem as an earlier poster... Outlook will send, Thunderbird will not.
channel
Bah! Just found the answer here:
http://portal.plus.net/central/forums/viewtopic.php?t=47761&highlight=thunderbird
Apparently you need to disable the username and password? Worked for me.
