does management only run from 4pm until 12 ?
if so then why am i stil stuck on 128k instead of my 2mb god +net you realy know how to treat your customers and dont give all the blahh blahh im not intested with excuse after excuse with your service soon as i can rid of the lease u got round my neck im out of here! and will also take this higher as im totaly discused by this service
:x :x
JonathanW
Which account type are you on, and which management are you refering to? As managmenet under the SUP is only 4pm - Midnight. Where as management on Plus accounts will run from 8am - midnight, similarly for Clean To management on Premier.
u lot get worse everyday!
blaze30682
so if ure on the £14.99 net option, we can only download 5gb a month betwwen 8 am and 12 pm?
Not quite.
You can download upto 5GB between the peak time of 8am and midnight without any speed limitation. After you exceed the 5GB allowance, you can still download data during the peak period but at a reduced speed. Any downloading between midnight and 8am is not counted in the 5GB allowance and is not speed limited.
tcs2000
Why do Plusnet have different peak times for different packagesHuh
Peak times should be the same regardless of what package you are on!
