dns still not working
these do not work for me
Primary DNS Server 212.159.13.49
Secondary DNS Server 212.159.13.50
i'm having to use other DNS servers, when is this going to be sorted out
waldron
They are working OK for me.
Fixes: 57
I have been using them since just before Christmas with no problems
Mand
Hi
How do you mean they do not work?
What sort of problem are you experiencing?
As others have said the servers appear to be working fine, and there is nothing reported in our monitoring system regarding those servers.
FWIW
It might be an idea to flush your internal DNS Cache
Go to command prompt and type IPCONFIG /flushdns
this should clear out any gremlins on the windows side of things.
I have found that this works when I have problems with DNS issues, and nothing else has changed.
Worth a try.
Regards,
Roger.
