dialup (remember that?!)
hi all
can anyone help me - my normal dialup is 0845 1400101 but i'd like to use the number that is not limited - i seem to recall a higher rate number that you can dial if you can't use the low rate one for whatever reason... did i imagine this? any help appreciated!!
1 REPLY
James
Are you referring to 0800 dialup?
If so, that doesn't come with normal ADSL accounts unless you have a non-connectivity broadband fault raised.
Or maybe I'm completely missing the point Smiley
