default mailbox
default mailbox
Once a default mailbox is renamed how do you log into the new name? I tried to get into it with just the new name and also with my log in name+new name but it still wont work. For now I have set the original name back as it originally was but I need to change it.
kevgti
default mailbox
You still just use your account name to login to the default mailbox after renaming it.
So if your account name is abc123 your default mailbox login is still abc123 after renaming it.
default mailbox
Thanks for that very simple but not what I expected!
