dc++?
dc++?
I use dc++ to access a private hub. Since boxing day I havent been able to reach it. The hub is active and working fine but i get 'host unreachable' - i cant even ping it.
has plusnet changed anything that could have caused this?
cheers
Plusnet Staff
Plusnet Staff
dc++?
Can you post a tracert/MTR to the server, might indicate where the problem is occuring.
Were you able to ping it before the problem started?
Have you tried rebooting your PC and router/modem?
dc++?
tried most of that - literally nothing has changed as far as I am aware.
what method would you suggest for pinging the host?
cheers
dc++?
Start>Run>cmd (or command if win9Cool
you should be presented a dos prompt type
ping whatever.the.ip/host.is
and is the server definitely up atm, maybe you should get someone else to ping it
you could use an online ping/tracert tool like http://noc.nekesc.org/nqt.php (just googled so dont know about reliablity)
dc++?
thanks - have solved it - peer guardian was the culprit
cheers
dc++?
lol, yea happened to me once a long time ago, had to get rid of it regardless of how nice a piece of software it is Cheesy
dc++?
Why not just add the IP to permenant allows? no need to uninstall. I have had strange blocks on PG2 - I am sure the IP ranges are a little over cautious.
