crazy useage
jrgrahamcov
crazy useage
Have you accidently turned on unsecured wireless networking on your router. If you have people can use your internet connection whenever they want.
Someone may have "borrowed" your PC when you were out.
What traffic does the usage page put the 6.6GB under ?
fezzy2001uk
crazy useage
my usage chart has gone crazy as my pc was switched off at 10.0pm on Thursday and never got switched on till about 4.0 pm Friday how can they say iv'e used 6.60 GB off peak .i only use a wired connection and i'm the only one to use my pc how can this be...anyone else getting there usage recorded wrongly..how many hours would it take to use 6.60 gb anyway :? :?: can this be sorted or is this the norm
fezzy2001uk
crazy useage
hi
it looks like the traffic is under web...
and no i have not changed a thing to do with the router..when i shut down everything is completely switched off i pull the plug from socket..so it is a mistery to me
thanks for your reply
bob
crazy useage
You need to raise a ticket, explain the situation and have it investigated. A few Megs may be accrued when no router is connected but 6.6GB suggests a faulty VMBU. Others have reported strange figures showing up so best to get it investigated.
tcs2000
crazy useage
The VMBU is never accurate.
My Friday off peak total showed as 0kb.
Was connected and using from 8am to 4pm...
dennisb66
crazy useage
Hi Fezzy,I had this problem a couple of months ago. I was asked to switch off for 24hours whilst +net investigated,no problem since. :lol:
Plusnet Staff
Plusnet Staff
crazy useage
I've passed the ticket on to the network guys for you so they can check what's happened here.
fezzy2001uk
crazy useage
many thanks to all that have replied hope to have it sorted soon
cheers bob
fezzy2001uk
crazy useage
me again
just checked my usage for today crazy again 2.56GB and only been browsing the web and nothings been downloaded ...god knows what it will be tomorrow as I'm not going to be online at all tonight possibly 200GB in the morning
dennisb66
crazy useage
Maybe i spoke to soon earlier.I have just noticed that i have recorded usage on Gaming of 1.46GB peak time and 2.99GB Offpeak.I never do any type of Gaming however, my 6year old grandaughter plays dressing up games on sites such as Barbie,would this be recorded as gaming?.If so it still seems a very high usage for the time she spends on it. Sad
crazy useage
See https://portal.plus.net/central/forums/viewtopic.php?t=54633 where I explain why the figures may not be accurate.
As for barbie, is this the game itself (running on your PC) or the barbie website. If the game, yes it could be counted but it does seem very high. If the web site, it would not be classed as gaming but as web.
dennisb66
crazy useage
It's the Barbie website Peter.
crazy useage
Time to raise a ticket if you are sure your overall usage is much higher than you think it should be.
suec45
crazy useage
1.5 gb on gaming is ridiculous, it woul dtake our family about 2 weeks to build up that amount and there are 2 of us online gaming every night.
ONline gaming usually uses a very small stream, about 8-12kbps just a bit more than a dail up modem.
James
crazy useage
Hi Fezzy2001uk,
I've just asked one of the guys in the Networks Team to look into this for you.
You should receive a response shortly.
