cost for transferring to payg
Right, so BB+ is screwed. Plusnet know the reason for the problem, have a document (written a story about it) but don't have a timescale for a solution.
So I'm looking to transfer either to PAYG or out of Plusnet altogether.
I followed the links on the Plusnet site to transfer to PAYG and text said there maybe an additional cost, when following that link it was a page not found. Does anything work around here?
So how much will it cost, if anything to go from BB+ to PAYG and the if BB+ is ever fixed back to it again?
All answers gratefully received.
Ideally nothing...
You may get differing replies though. Smiley
Zathras
It shouldnt cost anything to go BB+ to payg as theyre same base price, you might want extra GB tho. If you wanted to go back in theory it would cost £14.99 but they seem to be waiving that atm .
Thanks for the answers.
I'll try a change to PAYG then. I can't put up with BB+ any longer. If PAYG still sucks, I'll leave.
I've swapped to PAYG. Says it'll take 5-7 days. I hope it doesn't take that long, I want broadband speeds now. Not dialup BB+ speeds for another week,
...Says it'll take 5-7 days. I hope it doesn't take that long, I want broadband speeds now. Not dialup BB+ speeds for another week,
I see no other reason why it should take 5-7 days to transfer you from one account to another except that perhaps BTplus customer support isn't up to strength.
Zathras
Took less than an hour earlier today, but its getting late now.
AFAIK and I may be wrong here it's automated within workplace. I think the 5-7 days is just a standard thing...
Zathras
Also called James :lol:
Also called James
Relying on an over worked member of BTplus comms to accelerate a change over can't be the way forward surely; what if he's away for a week? Wink
If that is true then it could be simplified so that it becomes an instant change over, couldn't it?
Mine was done in less than 20 mins including a disconnection and reconnection.
Liam
This has been actioned for you and happened immediately. If you can let me know where you were told 5-7 days I can make sure the messaging is updated.
To take advantage of your new account, simply reconnect.
Liam
...member of BTplus comms...
Enough of that if you don't mind. We work for PlusNet.
It actually says that during the "upgrade account" process via the portal which is the way I did mine,and I sent "elvin" a PM asking if it did take that long....but it was done before I recieved his reply.Whether it is there just in case there is a problem I don't know.
Liam
Many thanks... I've made a note to review the process and speak to Content as necessary on Monday. Don't want to go confusing anyone! The 5-7 days quoted refers to regrades where speed is concerned (i.e. if a regrade order is being placed with BT). Looks like that needs clarifying.
Upgrades do take place immediately, and downgrades from your next billing date.
That's as well as maybe, but PlusNet is owned by BT Global.
Check your pension plan... Wink
