connections
connections
it took me hours to do removed plate on main bt line tried broadband worked
managed to download inportant files sorry for using alot in 1 day just to make
computer safe then rebooted found i couldnt connect or keep getting disconnected so i ripped up carpets to check cables and 1 of the cables was badly damaged replaced with new one and all seems to work well was going to buy a new modem so people with disconnections best to check all your gear including cables .
sorry to be a pain in the last 5 days with connections but customer advice was right hope it stays like this now.
squatts
Geez
connections
and ..............breathe!
connections
Certainly cheaper to check for yourself, than to insist on BT coming round to tell you its your problem and not theirs!
Good to see positive feedback for PN
