connection
connection
Hi, I have been with Plusnet for a couple of years and since upgrading to 2meg like a lot of other folk I now have intermittent connection. Would moving to another ISP make a difference?
connection
If your connection is losing synch periodically, then no. Moving ISP is unlikely to solve it.
There are a number of reasons this might happen. Some of which are down to your local set up and some are down to your line or BT issues.
Can you tell us what is happening and a bit of info about your kit. If you have a modem or oruter which can supply line stats, those would be helpful.
connection
Hi thanks for replying, I use an ADSL external modem and have recently had new boxes and cable fitted by BT. How do I check for and send stats?
connection
What ADSL equipment do you use?
Can't really answer your Q without that info as every unit is dfferent and some don't give line stats info at all.
