changing from outlook express
Sad please tell me how yo change fron outlook express to plus net the info i got re; tools those options do not come up in my tools
tia
rosy
I'm not quite sure what you mean exactly, Rosy :?
When you say 'PlusNet', do you mean you want to use the Webmail system offered by PlusNet instead of Outlook Express? Or do you mean you want to set up Outlook Express to access your PlusNet email accounts? Which tools are you referring to? Do you have some links to the 'info' you mention?
plusnet
yes i mean use the system offered by plusnet
thanks
Moderators note by rogerloxton: Full quote of previous post removed
p_w_d_stone
To use the PlusNet webmail system type http://webmail.plus.net into your browser and log in to your mailboxes using the same details you use for Outlook Express.
In summary-
Name: <PlusNet username or username+mailboxname>
Password: <PlusNet password or mailbox password>
As PlusNet only introduced their webmail as a temporary solution, there isn't a PlusNet branded help file, but there is official documentation available here.
If you have any problems then I'm sure someone here will be able to help.
Smiley
Moderators note by John (johnessex) Full quote of preceding post removed as per the Link:rules
