ccgi space down?
oakuka
ccgi space down?
is the cgi space down?
http://ccgi.oakuka.plus.com/forum
this is my forum i use, but its not accesseing it.
Is anyone eles's down?
ccgi space down?
Rumpus is working Ok
Which server are you on?Huh
oakuka
ccgi space down?
Im on the Humbug server.
My forum was working bout 9pm, just went to check it and its dead. Cry Im stumpd
ccgi space down?
Yep it looks like humbug is down as I cant access your site either Sad
Wake up DT. Can you give the server a kick. :roll:
oakuka
ccgi space down?
Chears :shock: Cheesy
ccgi space down?
Tis working.
val
ccgi space down?
There still seems to be a problem - I'm getting timeouts today when trying to access my site at http://ccgi.valsphotography.co.uk/gallery.php.
I managed to get through a couple of times earlier today, but it seems to be consistently timing out now.
However, after trying to access it, I do see a bunch of incoming from ccgi.plus.net:http to closed ports being 'Denied' in my firewall. Does that mean cgi's sort of working, but simply responding too slowly atm?
Regards,
Val
ccgi space down?
It may have something to do with the Telehouse outage earlier:-
http://portal.plus.net/central/forums/viewtopic.php?p=360814#360814
Plusnet Staff
Plusnet Staff
ccgi space down?
Two of the servers look to have been affected by the outage at Telehouse, but they are back up and running now. We noticed a brief period of sites loading slowly, but before the network guys did anything it went back to full speed and should be OK now.
Julie
ccgi space down?
I am having problems as well it was fine earlier
The connection has timed out
The server at ccgi.julesj.plus.com is taking too long to respond.
This is the reply I am getting
For your information I am on Humbug, but I beleive its not the database but the server that is the problem.
C100
ccgi space down?
My ccgi pages went out too !
... but they have just came back up Cheesy
Julie
ccgi space down?
Looks like they are back now Smiley
Edit spoke too soon they are timing out again Sad
dancecrave
ccgi space down?
Spoke to soon.
Its all dead now,
ftp telnet, http.
Sad
Al
10Mins later, all back now. What's going on?!?Huh
val
ccgi space down?
Yes, it was back on and off for a while, but it's timing out again now.
Regards,
Val
kitz
ccgi space down?
the cgi platform is spread over 4 servers, and its pot luck which server you land on.
For the past few weeks Ive been seeing signs of the platform beginning to slow down and today start timing out.
Ive been doing some monitoring of the platform this evening and it would appear that whilst all 4 servers are under heavy load, ccg02 has been performing very badly with loads in excess of 400 at some points.
Ive been unable to identify which server is timing out but I would think its fair to assume from what Ive seen that its ccgi02.
This would explain why you hit a server and it times out.. and then if you try again a bit later your site appears to be working again - ie youve hit one of the other servers.
Ive been trying to nag PN about this for several weeks now, but it seemed like I was the only one who was experiencing this, so I dont think its being taken seriously.
Ive also posted about this on PUG
http://usergroup.plus.net/forum/index.php/topic,3359.msg41168.html#new
