can send but not receive emails.
I have my migration go through today to pn however I can send but not receive emails. Does anyone have any suggestions why.
Is your incoming server (pop3) set to mail.plus.net ?
Yep, I have checked both mailwasher & OE6 still cannot receive them.
To see if your account is at fault:-
The bits you need to type in are in bold.
1. Open a new command prompt.
2. Type in 'telnet mail.plus.net 110 <ENTER>'
3. When you get message '+OK Hello there.'
Type in 'user <yourusename> <ENTER>'
4. The next message is '+OK password required'
type in 'pass <yourpassword> <ENTER>'
5. If all is well you should get an '+OK logged in' message
6. Type 'list <enter>'
7. You should get a list of numbers in two columns the first is the message id the second part is the length of the message...
If you fail to log in there may be a problem with your mail account.
To use another mailbox other than your primary default one your username will take the form <account name>+<mailbox>. The password is your PN account password.
