bt speed test---ip problem
chrisjon
hi
any one ideas on this from bt speed. several tries same result
The IP address discovered on the network associated with your telephone number:........... did not match the one we have logged from this browser/connection. Please check your telephone number and try again. If problem persists please contact your CP.
regards
Plusnet Staff
Plusnet Staff
I've not seen that particular error before. I don't suppose you're using a wireless connection and connecting to someone else's router in error? or connecting via a VPN or using a proxy server? Can't really think of any other reason for this.
Which BT Speedtest is it, the old one:
http://www.kitz.co.uk/adsl/btwspeedtest.htm
or the new one:
http://www.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml
chrisjon
hi
speedtester.bt.com
will try the other url
ta
