broadband premier 30.1?
i have had an email telling me that i was on a 20.1 contention ratio and now im being moved to a 50.1 ratio but broadband premier is supposed to be 30,1 isnt it?Huh
it is about the bt contention rate and not plusnets. from what i can tell we have been on a 20:1 contention ratio and now they are changing it to the 50:1 ratio it should be. we are still on the 30:1 contention ratio on plusnets network as always.
so it will go to 50.1 then?
Ben_Brown
Your BT contention will be 50:1, and your Plusnet contention will remain at 30:1.
ah what? premier accounts being moved to 50:1 BT contention?
No, they (unless you where on the BT 20:1 contention) have always been contended 50:1 on the BT network. It is only when you get into the PN network that this drops down to 30:1.
(TBH, I think PN should just quote the BT contention as that's going to be the biggest effect on contention)
I was under the impression that my premier account was contented 20:1 by BT at my exchange and 30:1 by +net.
As it stands I'm getting awfull contention issues with BT's network! Now if my line is moved to 50:1 at BT's end, it's gonna get a hell of a lot worse!
Ben_Brown
Premier accounts are 50:1 at the BT exchange and 30:1 on our network. There were a few 2MB connections that were originally placed on 20:1 as the 2MB 50:1 product didn't exist at that time, although the product has always been advertised as being 50:1 at the BT exchange.
phew!!!
But the business products have a BT contention ratio of 20:1?
Ben_Brown
The Business accounts are 20:1 at the exchange, Small Business and Teleworker are 50:1.
just thinking out loud......
what's the chance of swapping product to the business account, to see if that solves/helps my problems? I know it costs more, but that's not really an issue. Could I swap back if it doesn't help?
Plusnet Staff
Plusnet Staff
You could switch to a business account, but they have a 12 month contract so you wouldn't be able to switch straight back.
Drewy: If you're having problems with contention at the exchange end check the VP status for your exchange. If it's red then until BT add more circuits it won't be any (much) better
solstans,
My problem is that BT aren't aware of any problem with the exchange and +net won't log a fault with BT until my connection gets worse!
So I'm stuck with a connection problem, but because it's not enough of a problem no one is willing or able to help. Apparently 300-400kbits is totally acceptable for a 2meg adsl connection. Now tobe fair to Plusnet they are saying that BT will simple not log any problem with a line unless it's on average slower than 400k.
I think the situation stinks! But what can I do about it?
