broadband down again ?
It has just taken about one hour to get connected. (Line up but no VC.). No idea if this is my hardware, but doubt it. Are the recent goood times over the last few weeks, following the normal bad times over, - again?
Fixes: 8
Have you checked for an MSO?
http://usertools.plus.net/exchanges/mso.php
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
James
Hi Frank,
I'm just running some checks on your line to see if there are any issues. There doesn't appear to be a globally affecting issue on your exchange.
James
Frank,
Not seeing any issues at this end. The BT check is showing you as being logged in without any apparently problems at the exchange end.
What are you seeing from your perspective?
Now logged on.
But previously a return to a long standing problem of the line syncing at >7MB but no ip address from PN (ie no connection to PN) and the modem reporting failure due to lack of VC connection.
Could be my hardware of course, but has been working flawlessly for some weeks up to this point.
James
Could easily have been a blip at the exchange end.
