broadband activation
Hi could someone please activate my broadband account. I have a modem on loan which has showed solid dsl light for 3 days. When i go onto order tracker it says waiting activation. And dial up is getting me down
thanks in advance
Plusnet Staff
Plusnet Staff
If try and connect with your username and password, if BT have completed the work then our system will see your connection attempts and automatically activate the account for you.
Also Dave should have mentioned that your log in name is a little more than just your username. Wink
You need to use solidsilverlady@plusdsl.net and your password.
James
Re: broadband activation
thanks in advance
Just in case our automatic script doesn't kick into place, I've manually activated your account at our end.
As John says, you'll need to use solidsilverlady@plusdsl.net as the username.
