avatar
avatar
Anyone tell me how to upload an avatar?
I have the image on my webspace in a folder called "htdocs" but can't seem to get the url right to link to it. I think the htdocs folder is a Plusnet default setting cos I didn't put it there.
Ben_Brown
avatar
If you have uploaded an image to the htdocs folder you will be able to access it by going to http://www.mcpheators.plus.com/(image name)
avatar
avatar
@mcpheators
dont forget the www.
avatar
Cheers folks, that seems to have done the trick.
btw, what happens if you try to uplaod an image bigger than 10k.
Ben_Brown
avatar
Nothing as far as I know, however the moderators may remove the avatar.
LiamM
avatar
One of the moderators will promptly remove it Wink
By the way, I can't see an avatar showing.
Julie
avatar
Hi the Avatar is not showing
You need to put in this link
( Link removed by julesj )
Ben_Brown
avatar
I can see it!
Oh well...
Julie
avatar
How strange
It does not show in my browser, using firefox
Just tried I>E and it's there so apologies obviuosly a browser issue.
Ben_Brown
avatar
I'm using Opera if that helps....
lowry
avatar
Not visible in Firefox either here Sad
matt Wink
avatar
Bit late, but can see it in Deepnet Smiley
avatar
The problem is with IE, the url is malformed, but IE is showing it anyway.
mcpheators, you need to swap the '\'s for '/'s so it reads http://www.mcpheators...etc and that should fix it for everyone.
Regards,
Andrew D Wiles
