auto login missing
auto login missing
I just tried to set up auto login via the usual link on the login page. The link is now not active. I take it that means the page for auto login is undergoing some work.
A
https://portal.plus.net/support/features/autologin.shtml
auto login missing
The auto login page appears here; I can't test it though as I'm on a college PC.
auto login missing
The link on the main page doesn't work - but you can set it by using - https://portal.plus.net/my.html?s=0&action=autologin
Alecto
auto login missing
It works OK here.
Use My Account/ Connection Settings on the left of this page, then click the Auto Login button.
Wheelie
auto login missing
I also did the same thing Geoff did and it worked for me as well.
auto login missing
HI chrisofcov
your link works once signed in but the link from the sign in page is dead.
Thanks for your help
A
