asking for a re-train
ady
err how do i ask for one ? cus i bleeive i should be synchin at higher speeds than i am getting right now o.O
thx ! ady
Plusnet Staff
Plusnet Staff
Everytime you sync up with the exchange the equipment will recalcuate the sync speed, although this will be determined using the target SNR value that has been previously determined.
Do you have the line stats for the line?
James
Upstream xDSL Link Info
Loop Loss 34.5 dB
Margin 19 dB
Errored Seconds 0
HEC Errors 0
Cell Count 3568
Speed 448 k
Downstream xDSL Link Info
Loop Loss 59 dB
Margin 12 dB
Errored Seconds 7
HEC Errors 0
Cell Count 37018
Speed 1664 k
DSL MAX
Downstream Line Rate 1152
Downstream Line Rate Timestamp 22/09/2006 16:31:09
Profile Change Time 12/06/2006 07:41:50
Maximum Stable Rate 576
Fault Threshold Rate 403
Interleaved Auto
How did james end up posting stats for ilegal89?
If James had the figures to hand would Dave not have them also?
A
ady
erm that ^^
ady
e1337 hax ! Tongue
James
e1337 hax ! Tongue
Pretty much.
ph34r meh, etc.
ady
lol >_<
Tongue
oh guys with all this shorthand your confusing me.
e1337 hax
ph34r meh
I get the lol though.
A
Plusnet Staff
Plusnet Staff
James is one of the special people with a woosh fob so can run a woosh test on the line to get the stats.
The key part is
Loop Loss 59 dB
Margin 12 dB
The 59dB is very high which indicates a pretty long line. It's just within the limits for a fixed rate 1Mbps service (under 60dB).
The margin of 12dB is pretty decent, by default BT aim for an SNR of 6dB, but if the line is unstable, which can easily happen on a long line, the SNR figure will be increased by the kit at the exchange.
As such the line can probably support 2Mbps, maybe 2.5Mbps but the chances are that it would be pretty unstable.
ady
ye, i posted something last week
ill sum it up:
i had 600-900kb line varied alot between this
i used test socket, got 1,3mb ( now 1.6)
my line attenuation went from 40-60
and SNR was around 18 - now 12-14 ish
:S im jsut wondering why there was a huge jump from 40 to 60
James
The change in line attenuation will have not been as a result of the upgrade. The line attenuation will be related to the cable quality.
The noise margin will be related to the upgrade - BT will squeeze it down as much as possible whilst attempting to maintain stability in order to increase your sync speed.
I don't like the fluctuating attenuation figures that you're reporting.
ady
i dont get how a 20db+ can be added just because i took off the ring wire o.O
p.s. i have an electric garage reletively close, but i get no change, when it open closes, i cant think of anything else that could of caused this.
however my neighbours 2mg upgrade coinsides with the 40 +(20db) line attenuation
this is all so very confusing ;p
ady
8 days on, 1.3mb at least every day
1.6mb at the moment, during peak time SNR 14
still no bras upgrade Sad
pepsi_max2k
lol. that just made up for the afternoon of constant disconnections i've had. at least there's comedy to be found in them there plusnet hills...
and a bit more OT, i was syncing at either 4 or 2 mbps a few months ago (seem to change daily), then the modem broke and had problems syncing for a few days (well... maybe a litlle more. actually, ermm... "it has been identified that your line has reconnected 4192 times over a 24 hours period". *blush* i like to think that's a record or something good anyways...).
anyway, basically after that got another message through saying "BT will be pro-activly applying a capped profile to your line ...blahblah... BT will be monitoring your line for any changes. Where possible, the profile will be removed." and since then it's never synced at more than 2 mbps. not sure if it's related or not, but any idea if it'll ever magically get a little faster someday? maybe someone could try some of that woosh fob stuff on it? Wink
