ask a simple question!!
winnipeg1823
I raised a question ticket to ask a general question if my speeds were normal for someone on LLU.
Plusnet replied that I would have to go through the fault reporting process in order to get a reply. I didnt really want to go through all that, I just wanted a simple answer.
Would anyone like to comment on these speeds
28-06-2006 18:57:01 505.9
28-06-2006 18:56:40 502.4
28-06-2006 18:55:58 0
28-06-2006 18:55:44 0
27-06-2006 18:19:01 574.8
27-06-2006 18:18:36 563.8
27-06-2006 18:01:08 515.1
27-06-2006 18:00:48 516.4
26-06-2006 18:47:00 555.5
26-06-2006 18:46:35 554.6
25-06-2006 18:35:47 505.7
25-06-2006 18:35:26 515.1
24-06-2006 12:12:17 530.6
24-06-2006 12:11:55 522.9
21-06-2006 17:17:25 473
21-06-2006 17:16:57 471.6
21-06-2006 17:16:35 0
20-06-2006 18:04:33 506.5
20-06-2006 18:04:12 501.3
19-06-2006 17:50:51 492.2
Not quite as good as the 1meg I was getting before being switched
1 REPLY
Plusnet Staff
Plusnet Staff
Do you know what speed your line is sync'd at? And do you know your line stats. Depends really on what speed the line is sync'd as to whether I would say they were good or. Under 1Mbps sync they are probably fine, over 1Mbps and it may be worth trying at a few different times to compare.
