asdl disconnection when useing phone
adsl connection cuts of when I use phone
even just listening to dial tone
I am a new user with a dynamode usb modem and two line filters(ycl).
I have tried various combinations of phone and line filters(ones supplied) but without any joy
Any ideas
Les
espresso_mick
RE: asdl disconnection when useing phone
How have you got you filters/phones & configured?
> Any ideas
> Les
Hi Les,
This may be a problem with the filters, are you able to borrow a friends to test? I appreciate this may not be possible but if you it is a very good test.
Kind Regards,
Rob
| Robert Kelly.......................Unmetered & ADSL solutions
| Technical Support..................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
> > Any ideas
> > Les
> Hi Les,
Hi All
Just borrowed friends filters
Problem solved
Cant believe I got two duff filters
but I have.
How do I arrange for replacements to be sent ASAP
cheers Les
> Kind Regards,
> Rob
> Hi All
> Problem solved
> but I have.
> cheers Les
Hi again,
I've forwarded the ticket you raised to our Hardware returns dept who will update you on how to return the filters, we can then provide you with replacements.
Kind Regards,
Rob
Hi to PlusNet and everyone else.
I cant believe this poor guy had this problem! I have had the exact same problem, again I'm a new user, and I have 2 YSL filters supplied by Plus Net as part of the starter PCI package.
Unfortunately I am not in the position to borrow anyone elses filters.
Can you (Plus Net) arrange to send me out some more (preferably tested) filters and if they solve the problem I will return the duff ones. I dont want to send mine in first because a) I will be without adsl for about a week, and b) it might not even solve the problem.
Alan Choo-Kang
> > Hi All
> > Problem solved
> > but I have.
> > cheers Les
> Hi again,
> Kind Regards,
> Rob
