are all LLU connections going through the same SLOW gateway?
bluewhale
are all LLU connections going through the same gateway?
will that cause scaling problems as more of us are moved to LLU
and isn't there a backup gateway, so that when the primary is screwed as tonight then we can be switched over, thats assuming that it's a gateway problem
1 REPLY
Yes, all LLU connections go through ptn-ag1 gateway and because only LLU connections are using it it has no problem with coping with the load.
No idea if a backup gateway exists.
The problem was at the gateway rather than within the Tiscali network.
