anybody showed speed increase after being slow after 8meg ug
ok guys here it is.
was on 2 meg superb service speed and connections secound to none.
i have not long had the 8 meg upgrade, 2 weeks ago i think, but i have the crappest speeds ever, done both plus nets own, and the standart bt instructions they suggest for speed testing properly.
and the max speed i have seen is 3.2, right down to 1.7, that was after 5 attempts on the bt speed test,
on the bog stadard +net one i havnt seen above 2.7 even at 3 am in the morning.
i ave now raised this point with +net and iam awaiting a reply.
i also can say on the dissconnection front, its been suerb not one dissconnection at all, as i know some of you have reported bad connections,mine has been great.
but my question to any of you guys is this.
has any of you on the 8 meg upgrade had these kind of speeds and then it has gone to its full potential.
reason i ask is simply iam being told time again allow at least 2 months as max dsl can be like this for a while....well is it true and any if you seen it happen??
as i my doubts on this ever going to top speed.
thanks for your time guys.
James
If it's any consolation, I'm in a similar boat to you - have never seen over 4mbps, despite always syncing at 8192.
thanks for the reply.
couple of more questions.
do you think it will get better?
also iam actualy i contact with my modem customer support to, and they have just asked me for my snr figures, and when i told them my snr is downstream, 10.5, they told me this is bad and ring bt to check the line.
do you think i should, and if so who exactly do i ring and what do i ask for?
and what should my snr figures be?
I've seen 6.5Mbps on my connection, but only twice, and only for a short time!
how long you been upgraded m8,
best ive seen on p2p is around 180.
the fastes i sw was 307.00 on bt speed test, defianltly not right, and its starting to annoy me now.
Was upgraded 3 May, but it took something like 1½ months before my stable rate was increased from 2000 to 8000 - something to do with me having migrated to PlusNet apparently.
and would you say hen that your speeds are exceptable for 8 meg or not?Huh
If you mean acceptable rather than exceptable, then they pretty much are. MaxDSL is more sensitive towards things, and so speeds can vary a lot more than on previous BT broadband products.
