adsl upgrade
adsl upgrade
The months go by and the promised upgrade simply does not happen.
Please can you give me a deadline?
adsl upgrade
If it is the free upgrade program which BT are rolling out that you are referring to then enter your phone number here for an indication as to when yours might be done.
adsl upgrade
Hi all,
i have the same issue as ivylodge in regards to the free regrades that are going about. im currently on 1mb, but my life will support 2mb fine..
inputtin my number into that exchange database give me little details in regards to the regrades, i get this :
As part of the mass upgrade program for customers, BT have released information detailing the months in which exchanges will be upgraded.
DSLAM ID Information
HKU-ADSL-101 This DSLAM is marked as a trial exchange
You are on the DSLAM known as HKU-ADSL-101.
Record last updated: 11 Apr 05
What exactly does "trial exchange" mean? :? any help would be appreciated..
Cheers..
adsl upgrade
It's meant to be done first but this is bt. Have you entered your details into the upgrade checker I wrote (with lots of help).
adsl upgrade
Has anyone on a trial exchange got their upgradeHuh
