adsl installation
adsl installation
i have 2 main phone sockets in my house, 1 of these sockets is using a phone doubler with a phone extension into the room i will be needing the adsl connection.
how do i setup the microfilter with the phone doubler and do i need a third microfilter for phone extension socket?
Can this modem from dabs.com be any good for such a cheap budget price - Quicklinx: 14XKWS? I'd get if you recommend it or i'd just safely go for the Speed Touch USB kit with 2 filters from dslsource.co.uk.
1 REPLY
RE: adsl installation
Hi Spencer,
You'll need a microfilter for each phone socket you are planning to use otherwise you may experience interference on voice calls.
I'm not familiar with that particular modem, you may find more information on it at http://www.adslguide.org.uk
Regards,
Robert
| Robert Kelly........................Unmetered & ADSL solutions
| Customer Support...........................for Home & Business
| PlusNet Technologies Ltd...............http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
