actual speed not consistent with modem status
My modem indicates connection speed is 1152000 (after BT exch upgrade), however speed test on Plusnet shows usual speed I had when I was connected at 512 k
Why is this- is Plusnet thottling the connection speed?
probably
you can raise a ticket and get it sorted..
Many people have had the same problem.
thanks Chesterfield, will do
