access
access
Can't access it through my company's firewall. Old webmail works fine.
access
That is an issue you would need to raise with your company though.
PlusNet can't deal with blocks that may have been put in place on purpose.
New Webmail Beta Testing
Will you continue with the oldstyle webmail after the beta testing is finished. If you are only running the new version I won't be able to access email at work. My company will not make any changes.
access
The Beta webmail is intended to replace the current portal webmail system.
access
I don't know about the decision to be made regarding when the new system goes live.
However, access blocking put in place by your company is not for PlusNet to worm around. There are likely thousdands of companies that block such access out there, and it would be near impossible to change it such that all are accessable.
Have you ever thought that the company put blocks like that in place on purpose?
Is there any legitimate reason why PlusNet should provide a method to bypass security measures you company has put in place? Have you ever thought your browsing activity may against the workplace computer use policy?
