Zyxel 2602HWL setup help
SmellyWelly
I've just got this router and can't get it to work :-(
Can anyone offer me any advice please.
I have set it as follows:
Mode: Routing
Encapsulation: PPoA
Mux: VC
VPI: 0
VCI: 38
Username: ********@plusdsl.net
Password: *********
When I do a "Diagnose" I get:
Test ADSL Sync: Pass
Test ADSL (ATM OAM) Loopback Test: Pass
Test PPP/PPoE Server Connection: Fail
Ping Default Gateway: Fail
I have used Belkin, Netgear, Draytek routers before with no problem.
What am I doing wrong?
Cheers
Nick
alankay
SmellyWelly
Thanks for that - I'd not seen it and it never occurred to me to think about PPPoE/PPPoA..
I am currently connected using a Belkin router and it indicates that the connection is PPPoA.
Cheers
Nick
James
Does it work using a username of pleaseletmeconnecttotheinternetsanta@startup_domain ?
SmellyWelly
James
For a few seconds, I actually considered trying that - you got me :lol:
Have a good Christmas and New Year
Cheers
Nick
James
Hehe, it is actually a valid suggestion Smiley
Trying a username of anything@startup_domain will see if you can log into the BT end of things. If you can't it is possible that your hardware is faulty if you can log on using alternate equipment.
SmellyWelly
Just tried anything@startup_domain and it worked Cheesy .
But logging in with my normal username and password still failed. I tried resetting my password from the portal, then changed it back to its normal value. The portal did not confirm that the change was successful or not, it just went back to the change password dialogue. Is this normal?
Cheers
Nick
James
Hi Nick,
Definitely getting password rejections at this end. Can you delete the entire password field and try again?
SmellyWelly
Hi James
Tried that (more than once) - still no joy.
I'm baffled!
Cheers
Nick
SmellyWelly
Hi James
Fixed it! Did a reset to factory defaults, set it up and it now works Cheesy
Many thanks for your help yesterday.
Have a great Christmas and New Year
Cheers
Nick
James
And the same to you Smiley
Glad it's all sorted now.
